Was du brauchst
Look for the black screw covers near the top of the brush. Take the covers off with flat head screw driver.
Gently use a flat head screw driver to take of the black cover, covering the plastic shell.
Using your flat head screwdriver to go along the seams of the plastic shell till the shell pops apart.
Then take your Philips screw driver (ph1 size head) and unscrew the circuit board. The screw is located in the middle of the board.
Remove the black heater cover by sliding it off.
Desolder each of the four connections, and remove the circuit board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
