Zum Hauptinhalt wechseln
Conair True Glow Lighted Mirror LED Bulb Replacement
Was du brauchst
  1. Conair True Glow Lighted Mirror LED Bulb Replacement, LED Bulb: Schritt 1, Bild 1 von 1
    • Unplug and remove batteries to make sure the ring light does not turn on while repairing.
  2. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 2, Bild 1 von 3 Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 2, Bild 2 von 3 Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
  3. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 3, Bild 1 von 1
    • Push the cover towards you and slide away from the rest of the mirror.
  4. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 4, Bild 1 von 1
    • Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
  5. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to screw in the new LED light bulb in a clockwise direction.
  6. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 6, Bild 1 von 1
    • Take the cover and push it back down in place.
  7. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 7, Bild 1 von 1
    • Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
  8. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 8, Bild 1 von 1
    • Plug the mirror in and reinsert batteries to turn it on.
  9. Conair True Glow Lighted Mirror LED Bulb Replacement: Schritt 9, Bild 1 von 1
    • Enjoy your fixed LED ring mirror light!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dave Inthavong
216 Reputation
1 Anleitung geschrieben
York University, Team S1-G1, Woodhouse Winter 2021 Mitglied von York University, Team S1-G1, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G1
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
Bonnie Smith - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 90
Insgesamt: 2,459
