Einleitung
Use this guide to replace a faulty or shattered light bulb in your Conair True Glow Lighted Mirror (model TGBE104XCLED).
The light bulb is a piece of hardware that is used to convert electricity into light, consisting of a source of illumination enclosed within a transparent or translucent shell, typically having a rounded shape. For this device, use an all-purpose fluorescent 8W (watt) LED light bulb.
If your bulb is shattered, make sure to wear proper clothing and eyewear before beginning this guide.
Was du brauchst
Unplug and remove batteries to make sure the ring light does not turn on while repairing.
Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
