Was du brauchst
We will want to attach line power to the terminal labelled "line power"
We want to feed the line power transformer cable through this hole.
Connect the wires to the terminal block AFTER feeding the wire through the hole in the node enclosure.
Make sure the wires are connected to the terminal block in the correct order. Observe the solar panel wires to verify which way is correct.
At this point you should be done! Close up the node and figure out how to elegantly connect the waterproof transformer casing to the node so that it does not get ripped off. One option might be duct taping the transformer to the top of the node (under the solar panel)
These are pretty rough instructions. Further photo documentation and revisions are probably needed.
