Einleitung
If your camera lens is defective or damaged use this guide to replace it with a new one. Ensure your device is completely shut off before beginning this process.
Was du brauchst
Locate the camera lens near the top center of the tablet.
Disconnect the lens from the motherboard by lifting the tab holding the ribbon in place.
Pull out the camera by the ribbon.
To reassemble your device, follow these instructions in reverse order. Ensure the camera aligns with the back casing and front screen.
