Einleitung
If your Contixo V9 screen is damaged, use this guide to replace it with a new one. Ensure your device is completely powered off before starting the replacement process.
Was du brauchst
Carefully pry apart the back casing from the tablet using an iFixit Opening Tool.
Locate the ribbon attaching the screen to the motherboard towards the bottom left of the tablet.
Detach the old screen by pulling out the ribbon from the port on the motherboard.
