Einleitung
This guide will give you step-by-step instructions on how to replace the back door on your Contour Roam2. Follow this guide if it is damaged or the stays button is no longer working.
Was du brauchst
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
Grab the camera on both sides and slide the outer shell forward until completely removed.
Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
Open the back door by your thumb and index finger on sides of back door and pull upward.
Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
