Zum Hauptinhalt wechseln
Contour Roam2 Back Door Replacement
Was du brauchst
  1. Contour Roam2 Back Door Replacement, Record Slider: Schritt 1, Bild 1 von 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Back Door Replacement: Schritt 2, Bild 1 von 2 Contour Roam2 Back Door Replacement: Schritt 2, Bild 2 von 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Back Door Replacement: Schritt 3, Bild 1 von 2 Contour Roam2 Back Door Replacement: Schritt 3, Bild 2 von 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Back Door Replacement: Schritt 4, Bild 1 von 3 Contour Roam2 Back Door Replacement: Schritt 4, Bild 2 von 3 Contour Roam2 Back Door Replacement: Schritt 4, Bild 3 von 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Back Door Replacement: Schritt 5, Bild 1 von 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Back Door Replacement, Mounting Piece: Schritt 6, Bild 1 von 2 Contour Roam2 Back Door Replacement, Mounting Piece: Schritt 6, Bild 2 von 2
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Back Door Replacement: Schritt 7, Bild 1 von 2 Contour Roam2 Back Door Replacement: Schritt 7, Bild 2 von 2
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Back Door Replacement: Schritt 8, Bild 1 von 1
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Back Door Replacement: Schritt 9, Bild 1 von 2 Contour Roam2 Back Door Replacement: Schritt 9, Bild 2 von 2
    • Remove and replace mount piece.
  10. Contour Roam2 Back Door Replacement, Back Door: Schritt 10, Bild 1 von 1
    • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
    • After removing the metal bar, the spring will become loose and may fall out on its own.
  11. Contour Roam2 Back Door Replacement: Schritt 11, Bild 1 von 1
    • Remove and replace back door.
    • Door should easily be removed by pulling away from main body of camera.
    • As door is being pulled away, the spring may fall out own its own.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jamie Maple
310 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 4-5, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-5, Panko Spring 2015
UCCS-PANKO-S15S4G5
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,626
