Zum Hauptinhalt wechseln
Contour Roam2 Mounting Piece Replacement
Was du brauchst
  1. Contour Roam2 Mounting Piece Replacement, Record Slider: Schritt 1, Bild 1 von 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Mounting Piece Replacement: Schritt 2, Bild 1 von 2 Contour Roam2 Mounting Piece Replacement: Schritt 2, Bild 2 von 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Mounting Piece Replacement: Schritt 3, Bild 1 von 2 Contour Roam2 Mounting Piece Replacement: Schritt 3, Bild 2 von 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Mounting Piece Replacement: Schritt 4, Bild 1 von 3 Contour Roam2 Mounting Piece Replacement: Schritt 4, Bild 2 von 3 Contour Roam2 Mounting Piece Replacement: Schritt 4, Bild 3 von 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Mounting Piece Replacement: Schritt 5, Bild 1 von 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
  6. Contour Roam2 Mounting Piece Replacement, Mounting Piece: Schritt 6, Bild 1 von 2 Contour Roam2 Mounting Piece Replacement, Mounting Piece: Schritt 6, Bild 2 von 2
    • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
  7. Contour Roam2 Mounting Piece Replacement: Schritt 7, Bild 1 von 2 Contour Roam2 Mounting Piece Replacement: Schritt 7, Bild 2 von 2
    • Open the back door by your thumb and index finger on sides of back door and pull upward.
  8. Contour Roam2 Mounting Piece Replacement: Schritt 8, Bild 1 von 1
    • Using your thumb, pry sides outward on back of mount piece.
    • This will loosen mount piece for removal in proceeding step.
    • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
  9. Contour Roam2 Mounting Piece Replacement: Schritt 9, Bild 1 von 2 Contour Roam2 Mounting Piece Replacement: Schritt 9, Bild 2 von 2
    • Remove and replace mount piece.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Colorado Springs, Team 4-5, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-5, Panko Spring 2015
UCCS-PANKO-S15S4G5
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Hi i need this part...
julmarte - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 1,383
