Einleitung
If the tripod mount has become stripped or the slots that the plastic mounts slide into become stripped, follow this guide on how to replace the mounting piece on your Contour Roam2.
Was du brauchst
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
Grab the camera on both sides and slide the outer shell forward until completely removed.
Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
Open the back door by your thumb and index finger on sides of back door and pull upward.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
