Zum Hauptinhalt wechseln
Contour Roam2 Waterproof Action Camera Record Slider Replacement
Was du brauchst
  1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: Schritt 1, Bild 1 von 1
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
  2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 2, Bild 1 von 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 2, Bild 2 von 2
    • Rotate the metal ring counterclockwise until completely removed.
  3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 3, Bild 1 von 2 Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 3, Bild 2 von 2
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
  4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 4, Bild 1 von 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 4, Bild 2 von 3 Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 4, Bild 3 von 3
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
  5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: Schritt 5, Bild 1 von 1
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Colorado Springs, Team 4-5, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-5, Panko Spring 2015
UCCS-PANKO-S15S4G5
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - Antwort
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 914
