Zum Hauptinhalt wechseln
Coolpad Defiant Back Case Replacement
Was du brauchst
  1. Coolpad Defiant Back Case Replacement, Back Cover: Schritt 1, Bild 1 von 2 Coolpad Defiant Back Case Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Back Case Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover from your device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 323
