Zum Hauptinhalt wechseln
Coolpad Defiant Battery Replacement
Was du brauchst
  1. Coolpad Defiant Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Coolpad Defiant Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnny Boland
500 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,454
