Zum Hauptinhalt wechseln
Coolpix S01 Screen Cover Replacement
Was du brauchst
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: Schritt 1, Bild 1 von 3 Coolpix S01 Screen Cover Replacement, Screen Cover: Schritt 1, Bild 2 von 3 Coolpix S01 Screen Cover Replacement, Screen Cover: Schritt 1, Bild 3 von 3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: Schritt 2, Bild 1 von 3 Coolpix S01 Screen Cover Replacement: Schritt 2, Bild 2 von 3 Coolpix S01 Screen Cover Replacement: Schritt 2, Bild 3 von 3
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: Schritt 3, Bild 1 von 3 Coolpix S01 Screen Cover Replacement: Schritt 3, Bild 2 von 3 Coolpix S01 Screen Cover Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: Schritt 4, Bild 1 von 3 Coolpix S01 Screen Cover Replacement: Schritt 4, Bild 2 von 3 Coolpix S01 Screen Cover Replacement: Schritt 4, Bild 3 von 3
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Houston State, Team 2-3, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-3, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G3
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 556
