Zum Hauptinhalt wechseln
Coolpix S01 Zoom Trigger Replacement
Was du brauchst
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: Schritt 1, Bild 1 von 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: Schritt 1, Bild 2 von 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: Schritt 1, Bild 3 von 3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: Schritt 2, Bild 1 von 3 Coolpix S01 Zoom Trigger Replacement: Schritt 2, Bild 2 von 3 Coolpix S01 Zoom Trigger Replacement: Schritt 2, Bild 3 von 3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: Schritt 3, Bild 1 von 2 Coolpix S01 Zoom Trigger Replacement: Schritt 3, Bild 2 von 2
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: Schritt 4, Bild 1 von 2 Coolpix S01 Zoom Trigger Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
Abschluss
Sam Houston State, Team 2-3, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-3, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G3
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 380
