Einleitung
If the scroll wheel sensor on your Corsair Katar mouse is broken, this guide will show you how to replace it.
Was du brauchst
Remove the three skates on the bottom of the mouse using the plastic opening tools.
Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
Detach the bottom of the mouse from the upper shell.
Use the plastic opening tool to detach the white DPI sensor cable from its port.
Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
Use the plastic opening tool to pry the white cable jack away from the motherboard.
Lift the motherboard away from the bottom of the mouse.
Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
Desolder the 5 connecting pins to remove the scroll wheel sensor from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Do I need new pads when I take out the old ones or will the same one stick?
