Zum Hauptinhalt wechseln
Corsair Katar USB Cable Replacement
Was du brauchst
  1. Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: Schritt 1, Bild 1 von 2 Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: Schritt 1, Bild 2 von 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar USB Cable Replacement: Schritt 2, Bild 1 von 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar USB Cable Replacement: Schritt 3, Bild 1 von 2 Corsair Katar USB Cable Replacement: Schritt 3, Bild 2 von 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar USB Cable Replacement: Schritt 4, Bild 1 von 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar USB Cable Replacement, USB Cable: Schritt 5, Bild 1 von 2 Corsair Katar USB Cable Replacement, USB Cable: Schritt 5, Bild 2 von 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar USB Cable Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar USB Cable Replacement: Schritt 7, Bild 1 von 2 Corsair Katar USB Cable Replacement: Schritt 7, Bild 2 von 2
    • Use the JIS 0 screwdriver to remove the 5mm screw attached to the USB wire housing.
    • Lift the USB wire away from the shell of the mouse.
    • When reassembling the device, run the USB wire through the channel on the bottom of the shell to keep it in place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,278
