Was du brauchst
Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
Remove the panel.
Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
Dissemble the shell going up to separate the basket holder.
Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
Flip the device backward so the metal walls appear in a U-shape.
Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
Remove the heating coil.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
Le ventilateur démarre pas , c’est quoi le problème ?
Does anyone know what´s reference of ic1 is on the distribution board? IC1 Image
