Einleitung
This guide will show you how to easily replace loose or damaged ear cushions on the Cowin E7 headphones. When the cushions are loose or damaged, they will cause problems with sound quality and the noise canceling function.
Was du brauchst
Inspect the seal around the edge of each ear cushion for damage or instability.
Make note of which ear cushion needs to be replaced.
Spread multipurpose glue around the edge of the seal.
Place the replacement ear cushions where the damaged cushions were.
Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
