Einleitung
When you turn your device on, you cannot record.
Was du brauchst
Unscrew the 4 screws using the PH000 drill bit from the iFixit toolkit.
Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. This can be done by wedging the opening tool in the crack where the two sides of the device cover meet.
After it is wedged in push down on the exposed end until the two sides come apart.
In order to get to the wires of the microphone you will need to peel back the battery.
You will need to pull out both of the wires of the microphone connected to the motherboard in order to replace the microphone.
Next, you will need to take the new microphone and solder it to the motherboard using a soldering iron.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
