Zum Hauptinhalt wechseln
Cr-48 Chromebook Network Card Replacement
Was du brauchst
  1. Cr-48 Chromebook Network Card Replacement, Battery: Schritt 1, Bild 1 von 3 Cr-48 Chromebook Network Card Replacement, Battery: Schritt 1, Bild 2 von 3 Cr-48 Chromebook Network Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 1 von 2 Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 2 von 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook Network Card Replacement, Remove Screws: Schritt 3, Bild 1 von 3 Cr-48 Chromebook Network Card Replacement, Remove Screws: Schritt 3, Bild 2 von 3 Cr-48 Chromebook Network Card Replacement, Remove Screws: Schritt 3, Bild 3 von 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook Network Card Replacement: Schritt 4, Bild 1 von 3 Cr-48 Chromebook Network Card Replacement: Schritt 4, Bild 2 von 3 Cr-48 Chromebook Network Card Replacement: Schritt 4, Bild 3 von 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: Schritt 5, Bild 1 von 3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: Schritt 5, Bild 2 von 3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: Schritt 5, Bild 3 von 3
    • Once you've removed the lower case, you should see the network card on the corner of the device containing the USB port.
    • Disconnect the Wire connections on the network card using forceps or tweezers.
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: Schritt 6, Bild 1 von 3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: Schritt 6, Bild 2 von 3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: Schritt 6, Bild 3 von 3
    • Remove Screw securing network card.
    • Size ph#00, approximately 3 mm long.
    • Once the screw is removed, the network card will pop up.
    • Pull the network card to remove it from the device.
Abschluss
CSU Fullerton, Team 2-2, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 972
