Einleitung
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
Was du brauchst
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
Remove one black screw on the SSD using a PH #00 screwdriver.
Size ph#00, approximately 3 mm long.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
