Zum Hauptinhalt wechseln
Cr-48 Chromebook SSD Replacement
Was du brauchst
  1. Cr-48 Chromebook SSD Replacement, Battery: Schritt 1, Bild 1 von 3 Cr-48 Chromebook SSD Replacement, Battery: Schritt 1, Bild 2 von 3 Cr-48 Chromebook SSD Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 1 von 2 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: Schritt 2, Bild 2 von 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: Schritt 3, Bild 1 von 3 Cr-48 Chromebook SSD Replacement, Remove Screws: Schritt 3, Bild 2 von 3 Cr-48 Chromebook SSD Replacement, Remove Screws: Schritt 3, Bild 3 von 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: Schritt 4, Bild 1 von 3 Cr-48 Chromebook SSD Replacement: Schritt 4, Bild 2 von 3 Cr-48 Chromebook SSD Replacement: Schritt 4, Bild 3 von 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: Schritt 5, Bild 1 von 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: Schritt 5, Bild 2 von 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: Schritt 5, Bild 3 von 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: Schritt 6, Bild 1 von 2 Cr-48 Chromebook SSD Replacement, Remove SSD: Schritt 6, Bild 2 von 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Athar
365 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team 2-2, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 60
Insgesamt: 2,700
