Zum Hauptinhalt wechseln
Craftsman 944.360480 Carburetor O-Ring Replacement
Was du brauchst
  1. Craftsman 944.360480 Carburetor O-Ring Replacement, Carburetor O-Ring: Schritt 1, Bild 1 von 1
    • Make sure your engine is completely shut down and cooled off prior to starting this repair.
    • Put gloves on, so you don’t get any oil or gasoline on your skin.
    Frag FixBot
    Kommentar hinzufügen
  2. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 2, Bild 1 von 1
    • Use a flathead screwdriver and remove the 40 mm screw that secures the air filter and the case to the lawn mower.
    Frag FixBot
  3. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the air filter and set it aside.
    Frag FixBot
  4. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 4, Bild 1 von 1
    • Slowly remove the air filter case from the hinges by tilting it slightly and pulling it out.
    Frag FixBot
  5. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 5, Bild 1 von 1
    • Use the socket wrench and put the 5/16” inch hex bit on to remove the three 20 mm bolts located behind the air filter.
    Frag FixBot
  6. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 6, Bild 1 von 1
    • Pull the plastic backing off which will expose the carburetor.
    Frag FixBot
  7. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 7, Bild 1 von 2 Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 7, Bild 2 von 2
    • Use utility pliers to pull out the fuel line slowly by wiggling it up and down.
    • Have a container ready to pour out any extra fuel left in the mower.
    • Be sure to put a cloth or rag under if you don’t want it spilling anywhere.
    Frag FixBot
  8. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 8, Bild 1 von 1
    • Use the socket wrench with a ½” inch hex bit to remove the 11 mm screw on the bottom of the tank.
    Frag FixBot
  9. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 9, Bild 1 von 2 Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 9, Bild 2 von 2
    • Pull the carburetor tank down slowly.
    • Empty any extra gasoline and use a rag to clean it out.
    Frag FixBot
  10. Craftsman 944.360480 Carburetor O-Ring Replacement: Schritt 10, Bild 1 von 1
    • Remove the O-Ring from the carburetor tank and replace it with a new one. You are ready to reassemble your lawnmower!
    Frag FixBot
Abschluss
Priyum Mistry
181 Reputation
1 Anleitung geschrieben
York University, Team R-16, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-16, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG16
1 Mitglied
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 62
Insgesamt: 1,198
