Zum Hauptinhalt wechseln
Craftsman Model 315.10721 Blade Replacement
Was du brauchst
  1. Craftsman Model 315.10721 Blade Replacement, Blade: Schritt 1, Bild 1 von 1
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: Schritt 2, Bild 1 von 1
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Ziellinie
Cal Poly, Team 4-47, Amido Fall 2014 Mitglied von Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Where can I get replacement blades for this saw.
Edward - Antwort
Where can I get replacement blades for this saw?
Edward - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 75
Insgesamt: 3,208
