Zum Hauptinhalt wechseln
Craftsman Model 315.10721 Table Guard Replacement
Was du brauchst
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: Schritt 1, Bild 1 von 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: Schritt 2, Bild 1 von 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: Schritt 4, Bild 1 von 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 4-47, Amido Fall 2014 Mitglied von Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Where can I get a replacement table guard???
Roger Coyle - Antwort
Where can I get a replacement table guard for this jig saw????????
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 607
