Einleitung
Use the metal or nylon opening tool(s) to remove the back cover.
Was du brauchst
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Use a metal spudger to separate the back cover from the front touch screen.
To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
Continue to separate all of the clips around the device until the back cover comes off completely.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Como puedo habilitarle lo puerto usb ya k por error lo deshabilita en la bio y ahora me esta dando el error shell2.40 y no me funciona ni el clado ni el mouse en mi icraig cmp 801 bun
