Was du brauchst
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Use a metal spudger to separate the back cover from the front touch screen.
To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
Continue to separate all of the clips around the device until the back cover comes off completely.
After taking out the back cover, locate the black flap.
Open the black flap with the plastic opening tools.
Use the angled tweezers to pull the volume controls out and replace it with a new one.
