Zum Hauptinhalt wechseln
Craig Electronics CMP773 Screen Replacement
Was du brauchst
  1. Craig Electronics CMP773 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Craig Electronics CMP773 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: Schritt 2, Bild 1 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 2, Bild 2 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: Schritt 3, Bild 1 von 2 Craig Electronics CMP773 Screen Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: Schritt 4, Bild 1 von 2 Craig Electronics CMP773 Screen Replacement: Schritt 4, Bild 2 von 2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: Schritt 5, Bild 1 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 5, Bild 2 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: Schritt 6, Bild 1 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 6, Bild 2 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: Schritt 7, Bild 1 von 2 Craig Electronics CMP773 Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: Schritt 8, Bild 1 von 1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: Schritt 9, Bild 1 von 1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: Schritt 10, Bild 1 von 2 Craig Electronics CMP773 Screen Replacement: Schritt 10, Bild 2 von 2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: Schritt 11, Bild 1 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 11, Bild 2 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 11, Bild 3 von 3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: Schritt 12, Bild 1 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 12, Bild 2 von 3 Craig Electronics CMP773 Screen Replacement: Schritt 12, Bild 3 von 3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Abschluss
Justin mersch
205 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G4, Harley Fall 2019 Mitglied von IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
What kind of battery does this device specifically use
Kris Miller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 200
