Einleitung
It is common for screens on tablets to scratch, crack, and break from use. Also, screens may malfunction or stop working for a number of reasons. This step by step guide will lead you through disassembling your Craig Electronics CMP773 in order to replace the screen.
Was du brauchst
Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
Insert a plastic opening tool between the screen and the back of the tablet.
Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
Using your finger, remove the clamp that connects the screen power rib to the motherboard.
Using needle nose pliers, remove the ribbon.
Remove the second screen power connection from the motherboard using the same procedure as step 4.
Remove a single screw from the speaker using the Phillips #00 screwdriver.
Pry up on the locking tabs with the flat spudger.
With all screws and components removed, gently remove the motherboard from the casing.
Insert the spudger in between the screen and case. Work your way around the outside of the screen.
Grasp the exposed screen corner and gently separate the screen from the housing.
