Zum Hauptinhalt wechseln
Craig Electronics CMP773 Volume/Power Control Button Replacement
Was du brauchst
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: Schritt 1, Bild 1 von 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: Schritt 2, Bild 1 von 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: Schritt 3, Bild 1 von 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: Schritt 4, Bild 1 von 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: Schritt 5, Bild 1 von 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the old button and replace it with the new one.
Abschluss
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
IUPUI, Team S1-G5, Harley Spring 2018 Mitglied von IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 186
