Einleitung
Nozzles on a 3D printer are considered consumable items, meaning they are commonly replaced during a 3D printer's lifespan. The more you print the quicker the nozzle will wear out.
Reasons to replace a nozzle include:
- Desired nozzle diameter
- Clogged nozzle
- Nozzle deterioration
- First layer failure
- Print speed
This guide will demonstrate how to replace a 3D printer nozzle for the Creality CR 10s Pro V2.
Was du brauchst
Using a 2 mm hex key, remove the two screws that secure the fan cover.
Position the fan cover in a way that doesn't damage the external wires.
Remove the silicone sock from the extruder nozzle.
Go to your LCD Screen >Temp > Manual >Nozzle Pre-Heat.
Pre-heat the nozzle to 230C.
Once the nozzle is sufficiently heated, use an adjustable crescent wrench to firmly hold the heater block.
With the other hand, use the tappit wrench to unscrew the nozzle.
Allow the printer to cool down.
Once the heater block is cooled down, slightly thread the new nozzle onto the heater block.
Manually set the nozzle pre-heat to 230C and finish threading the new nozzle.
To ensure the nozzle replacement has been followed correctly, calibrate your 3D printer.
