Zum Hauptinhalt wechseln
Creality Ender 3 Pro and V2 32 Bit BL Touch Install Replacement
Was du brauchst
  1. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Probe and Probe Side Harness: Schritt 1, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Probe and Probe Side Harness: Schritt 1, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Probe and Probe Side Harness: Schritt 1, Bild 3 von 3
    • Attach the probe to mount with provided M3x 6 screws, positioning the probe with the connection towards the nozzle.
    • Plug in the connection like shown.
    • Final mounting should look like this.
    • Use provided cable ties and attach harness in 3 places. Do not over tighten the cable ties.
    • The probe mounting is a different between the Ender 3 V2 and Ender 3 / Pro but the bulk of this guide applies to all the 32 bit Ender 3 Variants.
    Frag FixBot
  2. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Board Side Harness: Schritt 2, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Board Side Harness: Schritt 2, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Install Board Side Harness: Schritt 2, Bild 3 von 3
    • See our Detailed Wiring Diagram
    • The original Z limit switch connection will not be used. Leave unplugged.
    • Use a provided cable tie to attach the BL Touch wires to the rest of the wiring bundle.
    • Assemble the green connector. Wiring must match through the connection but wiring order is not important to start. To be safe, assemble like in the picture.
    • Reinstall the bottom cover, making sure to plug your fan back in.
    Frag FixBot
  3. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Final Wiring: Schritt 3, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Final Wiring: Schritt 3, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement, Final Wiring: Schritt 3, Bild 3 von 3
    • Double check wiring before plugging the green connectors in or powering on the machine! If you mixup wiring, damage can occur.
    • Firmware is different for the Ender 3 / Pro , Ender 3 V2. Please contact us with your board type and machine for firmware and screen files.
    Frag FixBot
  4. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 4, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 4, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 4, Bild 3 von 3
    • Insert wisdom here.
    Frag FixBot
  5. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 5, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 5, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 5, Bild 3 von 3
    Frag FixBot
  6. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 6, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 6, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 6, Bild 3 von 3
    Frag FixBot
  7. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 7, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 7, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 7, Bild 3 von 3
    Frag FixBot
  8. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 8, Bild 1 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 8, Bild 2 von 3 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 8, Bild 3 von 3
    Frag FixBot
  9. Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 9, Bild 1 von 2 Creality Ender 3 Pro  and V2 32 Bit  BL Touch Install Replacement: Schritt 9, Bild 2 von 2
    Frag FixBot
Abschluss
Tiny Machines 3D Mitglied von Tiny Machines 3D
Community
5 Mitglieder
41 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 57
Insgesamt: 3,340
