Zum Hauptinhalt wechseln
Creality Ender 3 Pro Extruder Replacement
Was du brauchst
  1. Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: Schritt 1, Bild 1 von 3 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: Schritt 1, Bild 2 von 3 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: Schritt 1, Bild 3 von 3
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. Creality Ender 3 Pro Extruder Replacement, Wait for the hotend to heat up: Schritt 2, Bild 1 von 1
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. Creality Ender 3 Pro Extruder Replacement, Pull the filament: Schritt 3, Bild 1 von 1
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. Creality Ender 3 Pro Extruder Replacement, Set cooldown: Schritt 4, Bild 1 von 1
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
  5. Creality Ender 3 Pro Extruder Replacement, Extruder: Schritt 5, Bild 1 von 3 Creality Ender 3 Pro Extruder Replacement, Extruder: Schritt 5, Bild 2 von 3 Creality Ender 3 Pro Extruder Replacement, Extruder: Schritt 5, Bild 3 von 3
    • Use a 8 mm wrench or some pliers to unscrew the PTFE tube from the extruder mechanism.
  6. Creality Ender 3 Pro Extruder Replacement: Schritt 6, Bild 1 von 2 Creality Ender 3 Pro Extruder Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the single M3x18 socket head screw with a 2.5 mm hex key.
    • Remove the extruder arm and spring.
  7. Creality Ender 3 Pro Extruder Replacement: Schritt 7, Bild 1 von 2 Creality Ender 3 Pro Extruder Replacement: Schritt 7, Bild 2 von 2
    • Use a 2 mm hex key to remove the three remaining M3x10 socket head screws while making sure to not let the motor drop.
    • Remove the plastic bracket and the motor.
  8. Creality Ender 3 Pro Extruder Replacement: Schritt 8, Bild 1 von 3 Creality Ender 3 Pro Extruder Replacement: Schritt 8, Bild 2 von 3 Creality Ender 3 Pro Extruder Replacement: Schritt 8, Bild 3 von 3
    • Install the replacement extruder and screw it to the motor, following all the previous steps backwards.
  9. Creality Ender 3 Pro Extruder Replacement: Schritt 9, Bild 1 von 2 Creality Ender 3 Pro Extruder Replacement: Schritt 9, Bild 2 von 2
    • Reattach the PTFE tube to the extruder and insert some filaments.
Abschluss
Don't forget to recalibrate your E steps!
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 34
Letzte 30 Tage: 128
Insgesamt: 5,805
