Zum Hauptinhalt wechseln
Creality Ender 3 Pro Hotend Nozzle Replacement
Was du brauchst
  1. Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: Schritt 1, Bild 1 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: Schritt 1, Bild 2 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement, Hotend Nozzle: Schritt 1, Bild 3 von 3
    • Press the knob to enter the Ender 3 Pro menu.
    • Turn the knob to navigate to the temperature menu.
    • Click on the nozzle setting found in the temperature menu.
    • Turn the knob to set the nozzle to 200 C.
  2. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 2, Bild 1 von 1
    • Wait for the nozzle to heat up.
    • The nozzle will be at 200 C and should be handled with care to avoid burning yourself.
  3. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 3, Bild 1 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 3, Bild 2 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 3, Bild 3 von 3
    • Depress the extruder spring using the handle.
    • Pull the filament from the extruder, while keeping constant pressure on the extruder spring.
  4. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 4, Bild 1 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 4, Bild 2 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the two screws holding the fan shroud in place using the proper Allen key.
  5. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 5, Bild 1 von 2 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 5, Bild 2 von 2
    • The hot end is still at 200 C, so be careful not to burn yourself!
    • Remove the silicon sock covering the hot end and nozzle.
  6. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 6, Bild 1 von 2 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 6, Bild 2 von 2
    • Grab the hotend at the specified points using an adjustable wrench.
    • Be careful to avoid clamping the wires, ensuring the adjustable wrench only grabs the metal.
  7. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 7, Bild 1 von 2 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 7, Bild 2 von 2
    • Remove the nozzle with a 7mm socket wrench.
  8. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 8, Bild 1 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 8, Bild 2 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 8, Bild 3 von 3
    • Place the new nozzle within the 7mm socket wrench.
    • Grab the hotend using the adjustable wrench as seen in step 7.
    • Screw in the new nozzle again using the 7mm socket wrench.
    • Ensure the nozzle is hand tight as to not damage the hotend.
  9. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 9, Bild 1 von 2 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 9, Bild 2 von 2
    • Reattach the fan shroud by screwing in the two screws.
    • Place the silicon sock back on the hot end, avoiding contact with the metal.
  10. Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 10, Bild 1 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 10, Bild 2 von 3 Creality Ender 3 Pro Hotend Nozzle Replacement: Schritt 10, Bild 3 von 3
    • Navigate back to the temperature menu.
    • Set the nozzle temperature to 0 C, allowing it to cool down fully.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 28
Letzte 30 Tage: 68
Insgesamt: 1,115
