Zum Hauptinhalt wechseln
Creative Nomad Jukebox Zen Display Screen Replacement
Was du brauchst
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: Schritt 1, Bild 1 von 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: Schritt 1, Bild 2 von 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: Schritt 1, Bild 3 von 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 2, Bild 1 von 3 Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 2, Bild 2 von 3 Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: Schritt 3, Bild 1 von 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: Schritt 4, Bild 1 von 1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 5, Bild 1 von 2 Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 5, Bild 2 von 2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 6, Bild 1 von 2 Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 6, Bild 2 von 2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: Schritt 7, Bild 1 von 1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Abschluss
Austin Shaw
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S4-G5, Baechle Spring 2017 Mitglied von IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 525
