Einleitung
Hello! This guide will show you the steps to replace the damaged/cracked screen in your Creative Nomad Jukebox Zen Device and have you listening to your music again in no time! Please use caution when using the soldering tool.
Was du brauchst
Use the plastic opening tool to open the top cover by carefully prying at each corner.
Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
Using the plastic opening tool to pop the metal tab holding the battery in place.
Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
Use soldering iron to melt the solder used to hold the display screen to the motherboard.
Using the spudger tool, gently pry up the corners of the display screen to remove it.
