Zum Hauptinhalt wechseln
Creative Zen MicroPhoto Motherboard Replacement
Was du brauchst
  1. Creative Zen MicroPhoto Motherboard Replacement, Sliding Off the Back Cover: Schritt 1, Bild 1 von 1
    • Slide off the back cover to reveal the battery.
  2. Creative Zen MicroPhoto Motherboard Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
    • Removal of the battery may require some force.
    • Beginning with the notch directly beneath the battery, use the plastic opening tool to loosen the battery.
    • Once the battery is free, remove it from the device.
  3. Creative Zen MicroPhoto Motherboard Replacement, Separating the Front Cover: Schritt 3, Bild 1 von 1
    • Turn over the device.
    • Use the plastic opening tool to separate the front and back covers.
    • Move the opening tool around the perimeter of the device until the front cover detaches.
  4. Creative Zen MicroPhoto Motherboard Replacement, Removing the Front Cover/Keypad: Schritt 4, Bild 1 von 1
    • Slowly detach the front cover from the rest of the device to reveal the interior.
  5. Creative Zen MicroPhoto Motherboard Replacement, Disassembling the Internal Device: Schritt 5, Bild 1 von 1
    • Insert the flat-head screwdriver into the notch on the bottom of the device. Pry the main board and screen from the outer shell of the device.
  6. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board and Screen from the Device: Schritt 6, Bild 1 von 1
    • The power button will come loose upon removal of outer shell. When reassembling, align power button properly.
    • Remove the main board and screen from the outer shell.
  7. Creative Zen MicroPhoto Motherboard Replacement, Taking off the Back Cover of the Main Board: Schritt 7, Bild 1 von 2 Creative Zen MicroPhoto Motherboard Replacement, Taking off the Back Cover of the Main Board: Schritt 7, Bild 2 von 2
    • No tools are needed. The prongs (pictured) will release easily to remove the back cover.
    • Carefully remove the back cover.
  8. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Screen: Schritt 8, Bild 1 von 1
    • Be gentle when removing the main board. The main board is attached to the front panel of the device by wires.
    • Using the flat-head screwdriver, carefully pry open the prongs on the sides of the device, and remove the main board from the screen.
  9. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: Schritt 9, Bild 1 von 3 Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: Schritt 9, Bild 2 von 3 Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: Schritt 9, Bild 3 von 3
    • Do not damage the ribbon tab (pictured). It is vital to the device.
    • Push the ribbon tab (sticking out below the main screen) backward through the square hole to remove the main board of the device.
    • Once the wiring is removed from the front panel, release the hinge at the bottom of the device. To do so, gently pry underneath the clip (pictured) with a plastic opening tool. The clip will pop up, and the motherboard can be completely removed.
Abschluss
Elly
174 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-3, Buehl Fall 2014 Mitglied von Ohio State, Team 1-3, Buehl Fall 2014
OSU-BUEHL-F14S1G3
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 1,354
