Zum Hauptinhalt wechseln
Creative Zen Vision M Screen Replacement
Was du brauchst
  1. Creative Zen Vision M Screen Replacement, Opening the top: Schritt 1, Bild 1 von 2 Creative Zen Vision M Screen Replacement, Opening the top: Schritt 1, Bild 2 von 2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
  2. Creative Zen Vision M Screen Replacement, Opening the device: Schritt 2, Bild 1 von 2 Creative Zen Vision M Screen Replacement, Opening the device: Schritt 2, Bild 2 von 2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: Schritt 3, Bild 1 von 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: Schritt 3, Bild 2 von 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: Schritt 3, Bild 3 von 3
    • Disconnect the wire from the bottom device.
    • Handle with care as the wires tend to disconnect easily.
  4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: Schritt 4, Bild 1 von 1
    • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
    • Handle with care as the hard drive also comes off easily.
  5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: Schritt 5, Bild 1 von 1
    • Unscrew the seven screws placed around the mother board.
    • You will need a one millimeter Phillips head screwdriver.
    • The screws are small, so keep them safely.
  6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: Schritt 6, Bild 1 von 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: Schritt 6, Bild 2 von 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: Schritt 6, Bild 3 von 3
    • Flip your device upside down so that the motherboard will loosen.
    • Detach the connector from the motherboard.
  7. Creative Zen Vision M Screen Replacement, Removing the screen: Schritt 7, Bild 1 von 2 Creative Zen Vision M Screen Replacement, Removing the screen: Schritt 7, Bild 2 von 2
    • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
    • Lift the light gray flap to detach the screen from the motherboard.
  8. Creative Zen Vision M Screen Replacement, Seperating the digital display: Schritt 8, Bild 1 von 2 Creative Zen Vision M Screen Replacement, Seperating the digital display: Schritt 8, Bild 2 von 2
    • Separate the clear screen frame from the digital display.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kirstie G
470 Reputation
4 Anleitungen geschrieben
Texas Tech, Team 12-1, Bennett Fall 2016 Mitglied von Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 1,275
