Zum Hauptinhalt wechseln
Creative Zen Vision W Hard Drive Replacement
Was du brauchst
  1. Creative Zen Vision W Hard Drive Replacement, Battery Removal: Schritt 1, Bild 1 von 3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: Schritt 1, Bild 2 von 3 Creative Zen Vision W Hard Drive Replacement, Battery Removal: Schritt 1, Bild 3 von 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Hard Drive Replacement, Back Cover: Schritt 2, Bild 1 von 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Creative Zen Vision W Hard Drive Replacement: Schritt 3, Bild 1 von 2 Creative Zen Vision W Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Creative Zen Vision W Hard Drive Replacement: Schritt 4, Bild 1 von 3 Creative Zen Vision W Hard Drive Replacement: Schritt 4, Bild 2 von 3 Creative Zen Vision W Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
  5. Creative Zen Vision W Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 2 Creative Zen Vision W Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 2
    • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
    • Lift the metal cover off.
  6. Creative Zen Vision W Hard Drive Replacement: Schritt 6, Bild 1 von 3 Creative Zen Vision W Hard Drive Replacement: Schritt 6, Bild 2 von 3 Creative Zen Vision W Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lift the white and black ribbon connection off of the motherboard.
    • The hard drive can now be removed.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Tim Wilson
143 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-2, Regan Spring 2013 Mitglied von Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 3,715
