Zum Hauptinhalt wechseln
Creative Zen Vision W LCD Screen Replacement
Was du brauchst
  1. Creative Zen Vision W LCD Screen Replacement, Front Cover: Schritt 1, Bild 1 von 2 Creative Zen Vision W LCD Screen Replacement, Front Cover: Schritt 1, Bild 2 von 2
    • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
  2. Creative Zen Vision W LCD Screen Replacement: Schritt 2, Bild 1 von 3 Creative Zen Vision W LCD Screen Replacement: Schritt 2, Bild 2 von 3 Creative Zen Vision W LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Run the spudger along the cover and pry.
    • Do this gently to preserve the screen
    • The button pad may fall off when the cover is removed.
  3. Creative Zen Vision W LCD Screen Replacement, LCD Screen: Schritt 3, Bild 1 von 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: Schritt 3, Bild 2 von 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: Schritt 3, Bild 3 von 3
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  4. Creative Zen Vision W LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  5. Creative Zen Vision W LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  6. Creative Zen Vision W LCD Screen Replacement: Schritt 6, Bild 1 von 3 Creative Zen Vision W LCD Screen Replacement: Schritt 6, Bild 2 von 3 Creative Zen Vision W LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tim Wilson
143 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 17-2, Regan Spring 2013 Mitglied von Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Where can I get the screen
Home Watch - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,422
