Einleitung
This guide will show you how to access the motherboard and speaker on your device.
Was du brauchst
Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Run the spudger along the cover and pry.
The button pad may fall off when the cover is removed.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
Put the screen face down so you can see where the ribbon cables are attached.
Remove the red sticker that covers the ribbon cable connections.
Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
Remove the screen from the device.
Lift the keypad from the left side and use tweezers to slide it out to the left.
Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
Remove the ribbon cable from the keypad.
Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
Carefully pull the back cover off of the rest of the device.
The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
The USB input cover on the bottom of the device may also fall off.
Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
Lift the metal cover off.
Lift the white and black ribbon connection off of the motherboard.
The hard drive can now be removed.
Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0.
Use a small flat head screwdriver to bend the plastic tab holding the compact flash input in place.
The compact flash input should pop off easily, be careful not to break it.
Turn the device over so the side where the screen was is facing up.
Push on the motherboard lightly to separate it from the casing.
Turn the device over again and pull on the motherboard very lightly.
The speaker will be covered in a black glue and you must cut through this in order to remove the motherboard.
Turn the speaker on its side so it can fit through the casing and the motherboard can be removed.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
If the main board on vision w hard disk connector has 44 pins as vision m has but the vision w has a zif 40 pin ribbon in to the hard disk.it make me belive that it is possible to use a zif connector style hard disk on vision M to with the hard disk cable from vision w?Or does i miss something?i want to try to use a 1.8 hard disk with around 100 GB capacity on vision M if possible
