Einleitung
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
Was du brauchst
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the copper plate covering the motherboard by desoldering the ten solder points.
Remove the adhesive tape covering the three wires connected to the motherboard.
Desolder the solder points connecting the wires to the motherboard.
Disconnect the ribbon cable that is attached underneath the copper plate.
Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
The copper plate will be removed by now. However, the picture does not show this.
Lift up the motherboard.
A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
Remove the red and black wires with a soldering iron that are located underneath the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
