Zum Hauptinhalt wechseln
Cricut Explore Air 2 Front Door Replacement
Was du brauchst
  1. Cricut Explore Air 2 Front Door Replacement, Front Door: Schritt 1, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement, Front Door: Schritt 1, Bild 2 von 2
    • On both the left and right sides of the Cricut, locate the two internal screws.
    • Use a Phillips #1 screwdriver bit to unscrew the top 10.8 mm screw and the lower 9.1 mm screw on each side, four screws in total.
  2. Cricut Explore Air 2 Front Door Replacement: Schritt 2, Bild 1 von 1
    • Rotate the Cricut so the bottom faces upwards.
  3. Cricut Explore Air 2 Front Door Replacement: Schritt 3, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 3, Bild 2 von 2
    • Locate the four screws, two on the left and two on the right, with pads attached.
    • Using a Phillips #2 screwdriver, remove all four of the screws and their pads.
  4. Cricut Explore Air 2 Front Door Replacement: Schritt 4, Bild 1 von 1
    • Rotate the Cricut back to an upright position.
  5. Cricut Explore Air 2 Front Door Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the left and right sides of the Cricut's plastic shell off.
  6. Cricut Explore Air 2 Front Door Replacement: Schritt 6, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 6, Bild 2 von 2
    • On the right side of the Cricut, locate the circuit board screwed in to the cover just removed.
    • Locate the four screws securing the circuit board to the shell.
    • Use a Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  7. Cricut Explore Air 2 Front Door Replacement: Schritt 7, Bild 1 von 1
    • Gently unplug the connector from the circuit board, freeing the right side of the plastic shell completely.
  8. Cricut Explore Air 2 Front Door Replacement: Schritt 8, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 8, Bild 2 von 2
    • On both the left and right sides of the back plastic panel.
    • Using a Phillips #2 screwdriver, unscrew each of the four 5mm screws.
  9. Cricut Explore Air 2 Front Door Replacement: Schritt 9, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 9, Bild 2 von 2
    • Wedge a plastic pryer tool next to the left side of the back panel.
    • Gently pry the left side of the back door from the rest of the machine.
    • Repeat with the right side of the back door to completely remove the back panel.
  10. Cricut Explore Air 2 Front Door Replacement: Schritt 10, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 10, Bild 2 von 2
    • On both the left and right sides, locate the screws securing the top door's hinge.
    • Use a Phillips #1 screwdriver to remove the two 6.5 mm screws on each side, four in total.
  11. Cricut Explore Air 2 Front Door Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the lid off of the Cricut.
  12. Cricut Explore Air 2 Front Door Replacement: Schritt 12, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 12, Bild 2 von 2
    • Locate the screws on the corners of the metal interior plate on both the left and right sides.
    • Unscrew the two the 8 mm screws on each side, four in total.
  13. Cricut Explore Air 2 Front Door Replacement: Schritt 13, Bild 1 von 1
    • Gently lean the metal interior and all that comes with it backwards, exposing the bottom plastic shell of the Cricut.
  14. Cricut Explore Air 2 Front Door Replacement: Schritt 14, Bild 1 von 2 Cricut Explore Air 2 Front Door Replacement: Schritt 14, Bild 2 von 2
    • Locate the screws securing the front door hinge to the bottom plate of the Cricut.
    • Unscrew each of the four 5 mm screws on each side, 8 in total.
  15. Cricut Explore Air 2 Front Door Replacement: Schritt 15, Bild 1 von 1
    • Gently remove the front door from the bottom plate of the Cricut.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 228
