Zum Hauptinhalt wechseln
Cricut Explore Air 2 Roller Bar Motor Replacement
Was du brauchst
  1. Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: Schritt 1, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement, Roller Bar Motor: Schritt 1, Bild 2 von 2
    • With the Cricut open, access the two internal screws on the front left side.
    • Use the Phillips #1 screwdriver to remove the top 10.82 mm screw and the bottom 9.1 mm screw.
  2. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 2, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 2, Bild 2 von 2
    • Rotate the Cricut so the bottom is facing upwards.
    • Identify the two screws with pads.
    • Using the Phillips #2 screwdriver, remove both 42.77 mm screws.
  3. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 3, Bild 1 von 1
    • Rotate the Cricut back to its upright position.
    • Gently lift the cover on the left side of the machine to reveal the parts underneath.
  4. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 4, Bild 1 von 2 Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 4, Bild 2 von 2
    • Locate the circuit board on the cover just removed.
    • Use the Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  5. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 5, Bild 1 von 1
    • Gently unplug the connector, removing the circuit board.
  6. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 6, Bild 1 von 1
    • Gently unplug the connector located on the roller bar motor.
  7. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 7, Bild 1 von 1
    • Locate the three screws securing the plate holding the roller bar motor to the Cricut.
    • Use the Phillips #1 screwdriver to remove each of the three 5 mm screws.
  8. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the motor from the interior of the Cricut.
  9. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the white gear from the roller bar motor.
  10. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 10, Bild 1 von 1
    • Locate the two screws holding the roller bar motor to the mounting plate.
    • Use the Phillips #1 screwdriver to remove the two 2 mm screws.
  11. Cricut Explore Air 2 Roller Bar Motor Replacement: Schritt 11, Bild 1 von 1
    • Remove the motor from the plate.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 44
Insgesamt: 339
