Zum Hauptinhalt wechseln
Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement
Was du brauchst
  1. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: Schritt 1, Bild 1 von 3 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: Schritt 1, Bild 2 von 3 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: Schritt 1, Bild 3 von 3
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  2. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Bobber Valve: Schritt 2, Bild 1 von 1
    • Flip the lid over and expose plastic washer.
  3. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement: Schritt 3, Bild 1 von 1
    • Pull the plastic washer off the bobber valve and allow the bobber valve to fall out
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Ok I followed your directions but the new valve just keeps calling out?
dpataky1952 - Antwort
First time I used this but the bobber valve ports steam and does not stop ( unit is brand new )
Archerkc - Antwort
would be nice to see the other side of this. is it just supposed to be a hole on the outside up top? it is letting out air…when im trying to pressure cook.
shaycooks2 - Antwort
Ditto I was wanting to know the same thing!
kate2272 -
Ditto. Mine does the same thing.. suggestions?
Tina Royce - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 102
Insgesamt: 26,380
