Einleitung
If the steam release valve is broken or damaged in any way it will not seal and can cause a safety hazard when trying to open a pressurized pot.
If replacement of the Steam Release Valve Cover does not solve problem try replacing Steam Release Valve.
Was du brauchst
Orient the crock pot where the lid locked and unlocked icons are visible.
Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
Remove the lid.
Flip the lid over to expose the underside and the steam release valve cover.
Securely grasp the steam release valve cover. Twist and pull firmly to remove the valve cover.
3 weitere Personen haben diese Anleitung absolviert.
