Zum Hauptinhalt wechseln
Crosley 33301 Front Glass Replacement
Was du brauchst
  1. Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: Schritt 1, Bild 1 von 3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: Schritt 1, Bild 2 von 3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: Schritt 1, Bild 3 von 3
    • Rotate Clock till the face/or front is pointing away from you.
    • Continue on by unscrewing the 5.5 millimeter screws with your hands.
    • Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
  2. Crosley 33301 Front Glass Replacement: Schritt 2, Bild 1 von 2 Crosley 33301 Front Glass Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two remaining screws with a PH2 bit.
    • Do not be afraid to use additional force to remove these screws. Just be careful not to break the clock!
  3. Crosley 33301 Front Glass Replacement: Schritt 3, Bild 1 von 2 Crosley 33301 Front Glass Replacement: Schritt 3, Bild 2 von 2
    • Remove the front part of the clock from the back frame.
    • No major force is required. The back frame should slide right off.
  4. Crosley 33301 Front Glass Replacement: Schritt 4, Bild 1 von 2 Crosley 33301 Front Glass Replacement: Schritt 4, Bild 2 von 2
    • You will notice that there are three small indents on alternate sides.
    • You will see small slits where the indents can slide through.
    • Twist the center counter clockwise so that the face and the back are no longer connected.
  5. Crosley 33301 Front Glass Replacement: Schritt 5, Bild 1 von 2 Crosley 33301 Front Glass Replacement: Schritt 5, Bild 2 von 2
    • Replace the front of the clock with your new glass face protector and settle it on the frame.
    • The glass for this clock is 10cm in diameter. It would be best to use glass that fits this measurement!
  6. Crosley 33301 Front Glass Replacement: Schritt 6, Bild 1 von 3 Crosley 33301 Front Glass Replacement: Schritt 6, Bild 2 von 3 Crosley 33301 Front Glass Replacement: Schritt 6, Bild 3 von 3
    • Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tenaya
125 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 40
Insgesamt: 1,879
