Zum Hauptinhalt wechseln
Crosley CR704 Control Knobs Replacement
Was du brauchst
  1. Crosley CR704 Control Knobs Replacement, Safety: Schritt 1, Bild 1 von 1
    • Unplug the power cable if it is plugged in so that you don't electrocute yourself or loved ones.
    • Make sure the turntable cover is closed so that nothing jostles out of place.
  2. Crosley CR704 Control Knobs Replacement: Schritt 2, Bild 1 von 1
    • Using a spudger, gain a position of leverage and insert the end of the spudger into the gap between the radio knob and the device.
    • With some force, pry the knob off of its peg.
    • The knob should slide off smoothly, but beware of flying knobs!
  3. Crosley CR704 Control Knobs Replacement: Schritt 3, Bild 1 von 1
    • Applying some force, insert the replacement knob onto the peg.
Abschluss
Test by turning on your radio and playing a tune. We suggest "Last Dance" by Dona Summer.
MarkAnthony
772 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 1,818
