Einleitung
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
Was du brauchst
Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
Gently remove the back panel of the device being careful not to unplug any internal wires.
Carefully pull the wires out of their connections from the back of the speaker.
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
